Hi I have a 12" 3 phase wadkin bao that I run off a transwave converter. It's been running fine then today I went to start it, it tried to start up then went dead. I tried to start again and it's completely dead, I looked at the switches and wire connections and nothing seems to be wrong. I took the panel off the side and knocked the motor a bit. Tried again and now it hums as if trying to start but the motor just won't start. I've tried manually spinning the cutter block while trying to start it but still nothing. As I understand it being a 3 phase motor it won't have start capacitors so wondered if anyone had any other ideas what it could be? Or anyone in the Leeds area who you'd recommend to look at it
Any help would be much appreciated
Thanks Josh
Thanks Josh
