Bigbud78
Instead of starting two threads with my current woes I though I'd chuck em in the same one
Bought an old startrite mercury (mark 1) I've found there can be quite a bit of wobble on the drill bits I've found that if I run the chuck open and closed it significantly reduces, the chuck is stiff ! I'm assuming it just needs a good clean so I want to get it off before to clean before I buy a new one.
There are two rings above the chuck, the bottom one has come undone no problem but I cant work out how to get the chuck off, any suggestions ? or does someone know how to do it ?
Next
I've got an old Parkinsons Perfect vice that's gone quite rusty especially the two main mains (not sure of name), not sure if I should try taking it apart to clean up the rust of not ? Any ideas how they come apart ? I can't work it out or should I leave it together and do something else with it ?
All help gratefully received as always
https://dl.dropboxusercontent.com/u/986 ... .01.20.jpg
https://dl.dropboxusercontent.com/u/986 ... .02.02.jpg
https://dl.dropboxusercontent.com/u/986 ... .02.16.jpg
Next
