Vice jaws rack...
markturner
11 Mar 2011
London UK
Hi, I fitted a big heavy duty vice from Axminster to my bench and installed some beech jaw cheeks, approx 40mm thick , 170mm deep and 300mm wide. However, despite the vice having a double set of tubes as well as the screw, it still racks when you do it up. Any tips on reducing this or stopping it ? I thought the vice would be stiffer than this...
cheers, Mark
Paul Chapman
26 Jan 2006
Bookham, Surrey
Most vices rack, apart from the twin-screw, chain-driven ones. They usually rack when you are using only one side of the vice. All you can really do to stop it is to put a piece of wood in the other side. Some people make this packing piece adjustable by using pieces of hardboard screwed together - rather like feeler gauges.
Cheers :wink:
Paul
Streepips
6 Oct 2007
Lincolnshire
As Paul says above, racking is easily catered for with compensating pieces, but another thing to consider is if the workpiece is too small for the vice? IE: would using a smaller vice work better with the pieces you are clamping?
markturner
11 Mar 2011
London UK
Hi, I had been using the compensating piece solution, I just wondered if it was normal, as I had some trouble re assembling the vice when I fitted the cheeks, and wondered if it may have been related, however, it seems not. thanks for the advice! as always!
cheers, mark
custard
20 Aug 2008
Hampshire
Another vote for the "feeler gauge" solution.
I use a thinnish, 125mm long bolt with a penny washer at each end, between the washers are a selection of 125mm x 40mm shims in various thicknesses of 5-20mm, adding up to about 100mm thick in total.
It lives in the tool tray, and I'll fold out a combined thickness that's roughly equal to the work piece thickness and pop it in the "open" end of the vice. Having all these shims on a bolt, rather than loose, makes it easy to set in the vice without needing three hands, and they don't get lost!
bugbear
16 Jul 2004
North Suffolk
Paging Alf, paging Alf...
BugBear
