Nigel
This is a silly question from an old novice
I have just received a new veritas Honing Guide and within the packaging is a self adhesive rubber patch the same size as the bed of the clamp
as I do not see the brass wheel getting a puncture I assume it is for the clamp bed but I am puzzled that Veritas did not fit it or is it an option for special blades and also if fitted you lose sight of the lines on the base which I would use to keep a blade square, am I missing something,
