Varnished kitchen worktop in lousy condition - which sander please?
WannabeeCarpenter
15 Nov 2020
Shropshire
I'm finally getting round to decorating the kitchen and the worst part is the worktops. They're wood & were originally varnished (Wickes fitted kitchen) but the previous owners weren't exactly careful so it's both worn and stained. I don't really want to go to the expense of new tops so the plan is to refurb them.
Am I right in saying that an orbital sander is the one to use plus a shaped one for the corners? From what I've read a belt sander would probably be too aggressive but I'd like to get the job done as quickly as possible but without causing any damage :)
Secondary question: please can anybody recommend an oil? I've sanded a few patches, tried 3 very different Osmo oil colours and I actually can't see where they've been applied?!
**EDIT**
To all those who recommended a cabinet scraper........thank you.
One arrived today and in just a couple of minutes I could clearly see the area I tested it on. Not only will this save time & dust but I'll have Popeye forearms at the end!
Take a look at Rubio Monocoat oil. I've been using it for years now on wooden kitchen worktops.....never had any issues or failures.
what sort have budget have you got for the sander and will you have use for it afterwards?
Ordinarily I have a 'DIY budget' but I'd happily move upwards as a) I'm not looking forward to doing the kitchen so want to make it as easy as I can, and b) I'm slowly getting into woodworking so it'd almost certainly be used again.
How about £150 - would that get me something half decent?
plenty of options for the 100 - 150 mark, dewalt, makita, milwaukee all have corded options for random orbit sanders in that price range, arguably you could get away with the erbauer or makita MT (red) one for about 50, but IMO your better off spending a bit more if you want it to last. I haven't bought a sander for ages so I'll let others wade in with recomendations for individual machines
Rustins Danish oil has a really nice finish and seems to work well. You have to be patient enough to apply it properly though and allow it time to “cure”. It does yellow the wood a little, but looks great IMO. I did a new beech worktop last week & can post a photo if that helps? I can’t help on the sander (I use various Festool with the dust extraction) however I have heard that there are 101 variants of the Mirka Deros sold under different names, some within your budget. That’s a good sander, so probably what I’d look at in your shoes.
If a pic isn't too much trouble then yes please!
One of our worktops is in need of attention. I am tempted to plane it rather than sand it.
When I first got a decent ROS it was a revelation, one of the few tools I instantly wished I’d bought years before I did. I have a Makita BO6030, that plus abranet and an extractor makes fast (and clean) work of sanding, which let’s be honest, is not the fun bit.
Aidan
Someone with more knowledge than I may like to comment.
Is it the sander or the abrasive that is key to getting a quick and decent result.
Should the job start with (say) a 120 grit followed by 240 grit. Or just 240. How fine a grit is required for a decent finish.
Spending £5 on a cabinet scraper might be worthwhile, to remove the varnish before sanding. You can just draw a file along the edge at 90 degrees to sharpen it as you don't need a fine edge for that job. Hold either side, press with your two thumbs in the middle, angle it forward slightly and push. Varnish slices off, and no dust. I reckon it's about 5 mins to remove 1 square metre - then it gets too hot and your thumbs are tired.
Sand afterwards, but you'll have a lot less of that to do.
It’s both, plus extraction, you need to get the waste out before it clogs.
A good sander will make a far smoother job with the same paper as a cheap one, a bit like a decent coffee machine and a cheap on with the same coffee.
I’d scrape what I could off as it’s faster then start with 60 grit and go up, 80, 120, 180, 240, higher than that probably won’t do much.
I was going to suggest scraping the varnish off, but the "tiddles beat me to it" All I could ad is aggresive scraping to try and get the stains off, then go to ROS., various grits as suggested. Yer still gonna have to scrape the corners down though.
Eric
Reading this post with interest, I'm going to re do my worktop.
Does that RMO actually seal it? And how often do you do yours?
I used Osmo oil on a brand new worktop 18 months ago, I wasn't too happy with it .
Following this post with interest, its exactaly what id be asking,
(I'm redoing my top too🙈dreading it) I wasnt very happy with osmo oil, didnt think it the sealing lasted, unless I didnt do it right.🤷🏼‍♂️
Good luck with it.
If there's a lot of wear, a belt sander might be called for.
Or if you're a ninja with a smoothing plane, that would work also. :)
It would be best if you could remove it and give yourself some room, perhaps work outside.
Good luck!
You will regret the day you were born, using a belt sander is a definite no, unless you remove the work top.
Use a cabinet scraper and finish using a quality sanding sheet.
Cheap sandpaper will de laminate and bits of grit will leave nasty marks that you will then have to sand out..
Abrinet is the right move, cuts and clears well, outlast most other sanding sheets.
