Vacuum Pressing
Giff
14 Jun 2009
Cheshire UK
I eventually bought an expensive Vacuum bag set up for laminating and veneering. I couldn't understand why the bags / pumps didn't have a non-return valve and had to be left on continuously…….. so I fitted a non return valve and if you make sure there are no leaks you can switch the pump off and it holds the pressure. So after some Googling I found this site.
http://www.flickr.com/photos/95193440@N00/3514049014/
These seem to be the same units as you use for wine bottles, they are Vacu Vin and Amazon do them.
Bagging material is available here, and there is a good post on here on making your own system with lots of links.
http://www.ecfibreglasssupplies.co.uk/p ... -tube.aspx
I hope this maybe helpful to someone who wants to do occasional vacuum pressing or veneering with very little outlay.
Geoff
