Vacuum press
doctor Bob
22 Jun 2011
I seem to have developed an obsession with buying vacuum presses .........I don't need any more and yet I couldn't resist buying this one
Strange it used to be routers, now air presses rock :lol:
The good thing about this model is it can run 4 bags simultaneously.
Should sort out my pressed flower collection in double quick time allowing me more time for morris dancing
Don't knock Morris dancing, I did it once - if you get threatened by loads of big blokes in fancy dress with big sticks, I bet you would too!
PS do you want to get rid of any of your routers?
No, I'm still collecting just not quite so prolifically, 20 ish at last count, all used nearly on a daily basis, 12 of them are fixed in table set ups. 8 around one bench on swing up tables.
I must post a picture.
I'd be really interested to see your set up, in particular which insert plates you use.
I have a phenolic one which is generally OK but it does sag a little under the weight of a Trend 9. I'm guessing you must have beefier routers than that so will have a solution.
Just screwed to 18mm birch ply with a 50mm hole. Birch ply on hinges so they swing under the bench when not in use.
Following set up
Profile and scribe for spanish edge (2 x DW625)
4mm round over (trend t5)
shaker door profile (dw625)
drawer bottom groove (elu )
chamfer (dw625)
staff bead (dw625)
Ovolo edge profile (trend t10)
Plus a couple of tables
Extraction is done from above using magnets to clip on a flexi extension to the main extraction.
The real advantage of all this is set up time, my labour per man is about £35-£40 an hour, so if someone takes 15mins to set up a router it's cost me nearly a £10, very quickly get the return from investing in a few routers.
Thanks for the quick reply.
I did think that you might have discrete routing stations and the figures obviously more than justify that.
