Hi,
Wondering if anyone else has had any similar problem using a vacuum press to this and can give me a pointer on what I am doing wrong as clearly something is not right.
I am laminating plywood strips together to make my pieces thicker in places. For some reason my laminations are not getting properly stuck together.
After removing from the vacuum bag and the glue has dried I can peel the strips apart and obvoiusly have not bonded.
I have read if your laminations are not closing up then you need to increase vacuum but I am already using above the stated 25Hg.
I am using tight bond 3 glue and it is going off ok, temp here is about 15 degrees which is fine for this glue so this is not the problem.
I am getting 25Hg with the vacuum pump which seems to be the desired level from reading online.
I have tried another vacuum pump and pulled 27Hg and still have the same problem so I feel this maybe is not the problem either.
For my bagging I am using thick polyethylene sheet which I have made into a bag. I know the 2 main materials used are vinyl and polyurathane but I read online you can use virtually use anything?
I have seen a guy on youtube who seems to be sucessful in using a pond liner probably very similar to what I am using for a bag.
Ok so thats 2 possible problems, well if my vacuum dial is reading way off (which I doubt) or the vacuum bag material is somehow not right.
So on to the bagging proceedure. I have a joe woodworker venturi vacuum system (you can search that online) I am using the method provided on his site for laying out the wood.
I have an 18mm MDF backer board with cuts in the back face to allow the flow of air all over it to escape to the vacuum pump. Then I put the work on the inside face of this board and another board on top again with the cuts on the outsideface to allow air flow. This assembly then all goes into the vacuum bag. Sealed with tape..
Have also tried not using the top board, just using the plastic bag pulling down on top, which gave the same results.. the laminations were not properly stuck. I should give these boards the proper names the bottom baord is called the platen and the top board the caul I believe.
The strange thing I find about all of this is I can't find any information online about anyone else having a similar problem with joining wood with the vacuum press. All seem to be doing it without issue =) Any advice appreaciated.
