Vacum Chucking
paulkane1
21 Feb 2013
Belfast
I want to build a Vacum Chuck System for my Gradute Lathe,What kind of Vacum/Extractor is best to give the best suction for Large Zplatters /Bowls etc,I've read somewhere ,that a basic extractor is suffice,as,long as everything is well sealed on your Vacum System,Allnhelped is appreciated.
Yours Kindly Paul
If you are using a shop vac. make sure that it has a separate motor cooling circuit as opposed to most house vacs. that rely on suction airflow to cool the motor.
If using a higher quality vacuum pump be aware of the suction forces on large diameters, they can collapse a weak structures, provide a provision for pressure bleed or control.
Make sure you have a vacuum reservoir or alternate precautions that will hold the vacuum long enough for the lathe to stop if you have a power cut or emergency stop of any kind.
Yours Kindly Paul
From your post asking about tools for large bowls and platters I got the impression that you didn't have any tools at all and were just starting out. I would suggest that a vacuum chuck, whilst undoubtedly a useful piece of kit, is something that a beginner really doesn't need. The vast majority of turners will produce top quality work without ever using a vacuum chuck.
You would probably be better off spending the money on a regular chuck - you'll probably need one as well as a vacuum chuck unless you're always starting off with a nice flat piece of wood.
Having said that, my system uses a pump similar to those linked to by Robbo3. It looks to be slightly bigger than the first ones in the links. I think the advantage of these pumps over a system based around a vacuum cleaner/extractor is that they're happier running for longer periods and they're a lot quieter.
The main thing though is a wide enough chuck to provide enough surface area to hold a large lump of wood. You'll probably need a couple of sizes of vacuum chuck for different sized work.
I have also been looking for a vacuum pump to do this and I really like the price of these. Pauls suggestion of 8cfm is higher than I have seen elsewhere so I am off to have a read of his article :)
Just edited my post - it should be 8m3/h (which equates to 4.7cfm) not 8cfm.
If you look at the Airpress and Oneway vacuum chuck systems, they both use pumps of this spec.
