Using re-claimed timber indoors
No skills
6 Feb 2011
Hanging by my fingertips
I have various bit of reclaimed timber at home that I would like to use for some projects in the coming year. Some of it is treated, or at least I'm 99% sure its treated otherwise the softwood bits just wouldn't of lasted as long as they have in the postion they were in with no obvious protection.
I want to use an oil finish on a couple of the projects, question is will something like Danish oil seal in any nasty chemicals present in the timber? I don't want anybody exposed to whatevers in the timber. If not, other than painting the stuff is there any other finishes that would seal the timber?
Thanks for any help.
It will depend on the project? The treatments don't go that deep into the timbers - even the pressure treated ones. If you cut a section off a pressure treated timber you will see for the most part it only goes in a few mm. So depending on how you cut/plane the timber? You may well get rid of any treatment anyhoo :)
Any technical advice will give a worst case scenario. Use your brain - a bit of treated timber is not likely to harm anyone when used as a bookshelf - it may well do if you make chopping boards and babies' rattles out of it.
One of them is a blanket box, and thats the one I'm worried about. The main carcass will be the softwood, I was thinking about doing it with a frame and panel design but I havent the resaw capabilities to make the panels so a chunky design is in order thus keeping a lot of the timbers thickness.
Well yes there is that, whats left of it :) I just want to reduce any potential problems from touch or even off gassing from freshly machined treated stock. I have had some other treated reclaimed (from another source) that I wont use any more, in its un-molested state it just looks like some laminated timber - during machining and for a long time after (week or more) you can still smell the treatment in the timber.
