Using Melamine Chipboard as a Whiteboard
wcndave
5 Oct 2008
Truden, Italy
I have a large piece (2m x 2m) of Egger faced chipboard, white with a slight texture.
I notice that most whiteboards are really smooth and shiny.
Anyone got any experience using left over chipboard for a whiteboard?
Oddbod70
21 Aug 2020
Hampshire
Ages ago and it didn't really work. It marked really quickly because the pens didn't clean off properly - even when using the fluid.
Maybe try it and see? It'd be interesting to know.
wcndave
5 Oct 2008
Truden, Italy
I actually remembered that my wrist support for my keyboard is an old piece that i used to writes notes on or do quick calculation when at my desk.
On the bottom, it has some writing that has been there for 6 months. Didn't come off with fluid. However a little bit of jif/cif and it came right off. So I think I can clean with regular wiper day to day, and once every few months do a full clean with Cif.
I plan on putting a few off cuts in various places around the shop, next to machines etc, so when I am walking over repeating "19 x 243 x 649" over and over again in my head, I can just note it down.... or I often just need to do a rough paper and pencil calculation or make a note.
Oddbod70
21 Aug 2020
Hampshire
LOL! I have the same problem, except I write it down on a bit of scrap which then invariably gets used as a clamp pad. And of course I put the numbers next to the wood.
So next time I get some white chipboard I'm nicking your idea!
AES
18 Feb 2011
Switzerland, near Basel
I may well be (most probably am!) a boring old "puff of wind", but personally I find a bulldog clip with a bunch of scrap paper clipped in it does just as well. Bits about 100 mm square work fine for me.
I have a hook conveniently fixed above a couple of the machines where it comes in handy and other over the bench - hence total 3 "scribble pads" on which you can write with pencil, fibre tip, paint pen, biro, blood, or anything else that comes to mind - works fine for me.
BTW, I "made" a cheap worktop near the sink in my cellar worktop and inevitably it gets grubby. I use cif/jif (whatever it's called where you live - a cream-coloured sightly abrasive "cream") and after a while I've found that slowly but surely it's clearing the white melamine stuff off the base chipboard. Parts definitely look very thin and the parent "wood" is beginning to show through. But my "melamine board" may just be a cheapo substitute for the real stuff though
SammyQ
12 Apr 2005
A wee house on a hill
Lads, whiteboards are best cleaned with a properly intended fluid, one that has a surfactant in it. I taught off one for years, and believe me, nowt else takes ALL the writing off, quickly, permanently. Even "permanent" felt tips if you use them by accident.
A real whiteboard will also wipe clean quickly and easily with a proprietory 'duster' without resorting to fluid. Lasts for best part of a year with daily vigorous use.
Also, a chipboard surface is nowhere near the durability of the surface of a real whiteboard. For daily usage, being cleaned over a dozen times per day, no comparison.
Sam
