Using a router to make dowels
azk404
24 Dec 2020
London
Hello,
Is it a ok idea to use a 6mm straight router bit to make dowel holes rather than a doweling jig? I guess I would need to be very careful in marking up the holes but if the router was also on a track I feel like this might be quite good.
Any tips if so?
A
You can get 6mm dowel router bits from Wealden or Festool which are spiral. Is this for creating rows of shelf pin holes? Perhaps take a look at Festool LR 32 and DIY versions.
I've never tried making dowel holes with a router, so feel free to discount my responce, but I would stick with a dowel jig, £10 should get you something usable. My reasoning is this, a drill is designed for moving straight forward (ie making a hole) a router is designed for moving side to side (making an edge or a groove), so unless you eradicate all side to side movement you will get a slightly oval hole. To eradicate all side to side movement you'd need to construct a jig, get everything clamped etc, at which point you might as well have bought a dowel jig.
I've used a 6mm router bit for dowel holes many times in my router (mounted on a Woodrat). The bit itself looks (but may not be) very similar to the slot drills used in milling machines.
I've also used a good sharp 'lip and spur' drill bit.
Sorry didn’t get a chance to reply.
No it was going to be to create dowels to join panels at angles but looking at it this might be tricky so £30 dowel rig I found online looks a lot simpler actually.
The woodrat looks great but at £500 it’s a bit of an investment.
I should really just get a biscuit joiner to be honest which will probably save a load of time :)
Yes it’ll work.
But a router drill bit is the Gucci option if you are doing a lot
Aidan
Its probably best I will give both methods a try and see what which one works best. Thanks for the advice
