It's an American system Allan. The outer pane is sealed to the frame with silicon and the inner is sealed against a soft rubber seal with dessicant inside. What's the difference in practise to a sealed unit?
Sealed units fail 'cos the seal fails due to differential movement between the two panes, thus mounting two sealed but separate panes should, in theory, solve that problem.
Even if vapour does enter the dessicant should absorb a certain amount, beyond that the inner pane is removeable for cleaning and renewing of the dessicant.
as you say, time will tell.
Rod. According to my reading the likely cause is the seal has failed, then the air inside expands and contracts with temp changes, this sucks water vapour in which then condenses to a liquid.
Roy.
Roy.
