Two of a kind
KimG
Little Woodworm
2 Jul 2012
Pembs
A couple of natural edged bowls, both having a similar colour and colouring technique, but differing widely after that.
Both made from Ash (but totally separate bits, i.e. they came from different trees) the first was made from a small log as can be seen by the fact that the pith remains, it was intended as an exercise in executing a continuous curve with a small flare at the base, this was based on one of Richard Raffan's example pieces in his design book, it was a lot harder than I imagined, the reason being, if I made a small error in the sweep up to the natural edge, it meant that the whole shape had to change slightly to bring it back into line, plus it would have been very easy to remove to much and end up with top too narrow, I got about three passes to get it right, which I think I did, I am happy with it at any rate.
The next bowl is the spalted Ash with the mottled pattern I mentioned in Paul J's thread about Ash. I really like the way the colour has interacted with it. The primary thing that is very different with this bowl though is the finish, it is Shellac, the main difficulty with using Shellac on colour is that because it is also spirit based it will dissolve the colour and move it about, plus the rubber can get colour which can also be very problematic. Instead of a rubber though I used a small brush to apply the sanding sealer, then after it dried, a coat of heavy shellac (about a 2lb cut) this dries to a hard, but uneven finish which can then be sanded back to a smooth surface with 320 grit, just enough to remove the high spots, after that I was able to use the rubber with no colour problems. As a finish I find shellac has less of a plastic look and can be a little easier to buff glossy.
The foot on the bowl is reduce (about 2.5 mm) in response to the last discussion on bowl feet! :)
Colour was a thin mix of green blue and purple thinned with spirit, to give a lighter and more neutral colour.
I found both bowls tricky to photograph, and the first one has a rather grainy appearance.
Spalted Ash.
Very nicely done Kim.
The curves look spot on to me,which as you say isn't as easy to do as it looks.
The grain in your Ash is a lot tighter than what i have/had.
Thanks Bob, I do use photoshop, but the only sharpening I do is to the RAW file (I always shoot in RAW), your comment caused me to go back and have another look at my settings though, I see I made a fundamental error! The ISO is set to 1600 instead of the usual 100 I normally use, so the graininess is due to noise, I may shoot these again later as these images don't really do the pieces justice, they look better than this in the hand.
Cheers Paul!
Cheers Paul!
Did you leave the camera on your astro settings Kim?
No, it's been ages since I did any astro photography, I must have been photographing something pretty dim though (probably a selfie!) :D
An excellent pair, as usual, Kim. It will be interesting to see the same pics shot at 100 asa I suspect the difference will be huge.
Like the orientation of the first vase, regardless of the image resolution the colouring certainly accentuates the grain boundaries.
Have never got to grips with colouring pieces, main outlet shuns the practice and wants natural wood so don't get much incentive to use the dyes I have. The few pieces I have attempted were very much at the bottom end of desirable outcomes.
I have redone the images, this time at ISO 100, plus I used a diffuse flash as a fill, it has made quite a difference I think.
the colour really has a strong effect on Ash that way Chas, it's great when it works, but I have got my own collection of failures too. :)
A great pair Kim as for the colour the first one is the one that really stands out for me in form as well as colour. I like the iridescent look that you have achieved
I think I have said before that I am not a great lover of wood colouring, but boy does it make that grain pop in the first vase. Very nice Kim.
