Tv aerial
lurker
Le dullard de la commune
2 Mar 2007
Leicestershire
In the house I will be moving to......
Although I plan to have tv via bt internet, I also want one conventional tv aerial.
house had sky cable so currently has neither a roof aerial nor phone line.
I would prefer to put an aerial in the loft as I have no chimney.
anyone any experience of doing this?
does it need to be more “powerful” ?
where can I look to ascertain the size and type that I need?
Nigel Burden
23 Oct 2018
Dorset
My aerial is in the loft but I couldn't say whether it's more powerful. It was already in the house when we moved in in 1982, although I replaced the original years ago.
Below is a link to the BBC guide on choosing the correct aerial which might help. Otherwise get an aerial installer to do the job, they should have the knowledge of the correct type for your area.
Nigel.
Myfordman
AKA 9Fingers
19 Jan 2013
Southampton area
Using an in roof aerial is only sensible in a strong signal area. The roof material especially when wet will lose a lot of the signal. It is NOT just a case of using an amplifier as once lost you cannot get the same quality of signal back again despite what anyone might tell you.
flying haggis
7 Mar 2009
norfolk
whereabouts in the county of leicestershire are you so that we can figure out which transmitter you need to point an aerial towards. I shall assume you will be recieving from Waltham in the mean time
lurker
2 Mar 2007
Leicestershire
The transmitter is Waltham, I am in Loughborough.
I sort of assume that there is an online website that lists these things?
edit: it would appear that there is a relay station in Leicester which is were my new neighbours aerials seem to be pointing.
Lons
14 Feb 2010
Northumberland
Just a thought.
If they are leaving the sky dish up which is common then another option is to use that to get freesat, a basic box is quite cheap, possibly little more than a good aerial or pay more for recording facility.
You can also use an old Sky box to connect to freesat though I don't know if all progs are available it's very likely all the current freeview ones are and those boxes are available for almost nothing on facebook and gumtree. I've kept both our old ones in case I ever dump the Sky subscription.
flying haggis
7 Mar 2009
norfolk
Just a thought.
OP doesnt mention the prescence of a sky dish
Lons
14 Feb 2010
Northumberland
He said it has a sky cable so must have had a dish. whether there now is another matter.
Ah just realised that if it was cable services only similar to blocks of flats then ther might not have been a dish. :unsure:
Spectric
19 Feb 2015
North Cumbria
You don't need a chimney to fit a TV aerial, any wall will do that allows the aerial to face the transmitter you wish to receive from.
lurker
2 Mar 2007
Leicestershire
Nigel.
From that I can see my neighbours are actually pointing to waltham.
very clever!
I gave that to the scrap man :)
lurker
2 Mar 2007
Leicestershire
I said that it had sky cable but I ripped it out.
House was like a spiders web, inside and out
Duncan A
8 Nov 2007
Northants
From what you say, your neighbours have external aerials - presumably because a loft aerial would not do the job
Duncan
lurker
2 Mar 2007
Leicestershire
Duncan
I think it's just because it's the normal thing to do.
I agree that I might be making a rod for my own back.
Spectric
19 Feb 2015
North Cumbria
Here is some extra info, there is no such thing as a "digital aerial" which was a common talking point ever since the digital switch. You also do not need a wideband aerial because you only want to receive from your chosen transmitter group and this can help with issues surrounding interference from mobile phone mask. Yes that is another good topic, it is the reason why it went digital in the first place, they needed to allocate frequencies for mobile phones currently used by analogue tv and as there are only a limited number of frequencies going digital allowed for multiplexing of the Tv channels so you can transmit more channels using less bandwidth. So they were not thinking of us the end users at all, it was commercially driven.
flying haggis
7 Mar 2009
norfolk
as loughborough to waltham is probably about 15 miles as the crow flies I cant see why a loft aerial wont work. easier to put up than climbing on the roof or up a ladder on a wall so give atv a ring and diy. it will also last longer as it is protected from the weather. also factor in the cost of decent cable ie CT100 dont skimp it's not worth the hassle
lurker
2 Mar 2007
Leicestershire
Nigel.
very clever!
16 miles apparently :)
it was to avoid getting up a ladder was my main objective.
I think I will put it in the loft and if there are problems then reluctantly fit it outside.
lurker
2 Mar 2007
Leicestershire
Would this be good enough
Phil Pascoe
29 Jan 2012
Mine was in the roof in my old house - I turned the last few inches of a three foot piece of 2" x 2" round and hung it from a truss so that I had easy 360 degree adjustment.
