brianhabby
Has anyone turned using plywood? It's something I though of some time ago and did this today:
It is about 4" tall - it started life taller but broke during turning. It was the plywood lamination that broke, not the glue joint. Wax finish.
I found scrapers were easier to use than cutting tools and have to admit to using more than the normal amount of sandpaper. You can still feel a bit of roughness and if I do more I will spend even more time on the sanding.
regards
Brian
regards
Brian
