wcndave
I bought a large and small tacwise electric brad nailer set a few years ago when on offer. When I came to use them years later they couldn't drive a pin through pine! Completely useless.
Recently I was at a shop where the guy cleaned all the gunk from machines with an air pistol so I have taken the plunge.
Got a makita ac1300 20l 10 bar.seems a nice little unit. A makita af505 18 gauge brad it's on the way.
As usual the instructions would have been more valuable written on rice paper!
A few questions.
1. Normal for the device (pistol right now) to bleed when on?
2. Can I leave outlet valve off with machine on for extended periods so no bleed and ready when I need?
3. Says that at night I should bleed by pulling in out air. Makes no sense...do I need to bleed using outlet at bottom of can and is out the way? Seems more an emergency release. Also says I should bleed water every four hours by tilting, however can't see where it would come out..
A few questions.
