Triton TRA001 NVR operation U/S
Hemsby
9 Dec 2013
Lincolnshire
My router N V R function seems to have ceased :( .
After a power interruption while running, without any interaction from me the router will start when the power is restored #-o .
Is there home cure for this fault or is it a return for repair. It is just over a year old but still under warranty.
Any thought’s please.
phil.p":2jbjrn22 said:
If it's still under warranty why even think about touching it? Just send it back.
Sometimes an hour or so home fix (hammer) is better than the time and aggravation of returning an item for repair.
Obviously if no forum member has experienced this problem or it seems like a major job I will return it for repair. From previous experience of Warranty repair it can take a couple of weeks before the item is returned 8-[
Myfordman":174kveng said:
I've never seen a router with inbuilt NVR. Are you sure it has one?
Or silly me #-o .
Senility seems to be setting in. Got myself confused with the locking mechanism on the switch when cutter changing.
Thanks for the replies and the lesson "check before asking"
:oops: :oops: from Lincolnshire
