triton router mounting in table?
selly
4 Mar 2007
folks I bought a triton router and not sure how to mount it in my table.
I've bought a router table insert and a set of screws from axminster by trend assuming they would have the correct thread.
They're not. They appear the same size but the thread is different.
What screws do I need to buy (countersunk) to get this to work as they need to longer than the ones on the faceplate?
I'd contact Axminster, ask if they can provide the correct length of matching screws and arrange for a return.
I fitted mine by removing the plastic sub-base on the bottom of the router. I then used the screws that held on the sub-base to hold the router to the plate.
i too removed the plastic base and used the original screws supplied. Its a faff if the table is not its premanent home but if it is then its acceptable.
