Triton router/Axminster plate fitted.
beejay
21 Jan 2005
North Wales
I managed to get the Router fitted to the insert plate at the weekend and it has worked out really well :eek:
No real problems other than finding the courage to drill the holes in the plate but after checking everything 3 times I went for it.
The end result is a perfect fit and a set up that is so easy to use. At last I can change bits above the table,,and no special kit required :D
The height adjustment is a breeze and the router and plate simply drops in and lifts out when i'm finished.
I can see no flex in the plate after leaving the router attached now for several days so I think it should be OK.
All in all,, i'm one very happy bunny :D
Sorry but I still cant post pics you can however see it all at the following link.
beejay
http://community.webshots.com/user/eunos9
