Trend T4 router mounting in table top table.
Des333
27 Jun 2016
Newcastle upon tyne
Just bought a Trend T4 for some light hobby work and would like to mount it under small table top router table, home made, how do I do it?
Will the router baseplate fix to a plate fitted in the table and what kind of fixing do I need?
Will the plunge pillars and spring get in the way of mounting or can these be taken off?
Thanks for all instructions.
PeteHB
20 Oct 2016
Grenoble
Here you go a plate that will accommodate your T4 have a look in information and downloads in the link it should explain everything
Des333
27 Jun 2016
Newcastle upon tyne
Thank PeteHB, I’ve looked at a lot of plates and eventually made my ow for a trim router, works ok but wanted a more versatile tool hence T4. Bit of a pricy solution but may be worthwhile.
John Hall
19 Jan 2022
Manchester
The small ones on 1/4” arbors
Thingybob
If it aint broke dont fix it
9 Mar 2021
Teignmouth Devon
Bit late in answering this thread , I have a T4 Inverted in an Aldi ally router table for making my miniature mouldings works well made perspex plates to fix to guide the only trouble with the router spindle stop weak bent after a short while and plunge stop is plastic fitted to 6mm nut spun round after a few actions, My remedy for the spindle stop was to remove it altogether and use two spanners and the plunge stop i made a new one out of perspex not broke yet , I will post some pics if any help
