Trend bulls eye cutter
doctor Bob
22 Jun 2011
Anyone got one, I just bought one, about £100 for the holder, £60 for one set of blades.
Just tried it and its hopeless.
Anyone got one, any tips to improve the cut, tear out is horrendous.
wellywood":2m7mocjf said:
Scuse my ingorance dr Bob but what is a bulls eye cutter? Is it anything like a rosette cutter?
Indeed, just different name.
I would have thought for a cutter of that size you'd need to be running at the lowest speed you can. I assume you have this mounted on your lathe, Bob?
just out of curiosity is the cutter sharp it may need to have a burred edge like a cabinet scraper to reduce the tearout also try adjusting the machine speed and feed rate
TC cutter mounted in a drill press. Tried all sorts of speeds.
The drill press ain't great as I only have a little one at present, sold my floor standing one as I never used it.
Ordered a new drill press today, coming Monday, hopefully that will help.
Out of curiosity what material are you trying to make the rosette in ? because the trend website says it is for use on mdf.
