Todays Boot Fair
SteveF
16 Sep 2013
Maidstone
Rebate plane was a good find and works well
Steve
    209 KB
    227.1 KB
:mrgreen: :mrgreen: Impressive, most Impressive :mrgreen: :mrgreen:
Welcome to Kent, England's Best Bootfairs
The fillister has been put to use already..it had a job waiting for it..so major result
i was hoping for a 778 but this has done all i wanted from it
my router will get stuck in back of cupboard now
the infill was just a bit of luck tbh...never owned on before
no makers name , sorby iron
it is very heavy and needs some work
the iron needs a sharpen
the sole could do with a "clean up"
it will hopefully be a user.....is it acceptable to polish \ hone the sole ?
i know it wont look in keeping with the aged look
Steve
carlb40":936u6tym said:
Well done Steve.
As to the sole that will depend on whether its flat or not.
i will stick a straight edge on it
if it is out i was just going to put some wet n dry on my surface plate and give it a once over
Steve
Well well! Further proof that Kent boot fairs throw up the best finds and that Jimi's concentrating too much on stargazing!
Three infills is my score so far in Kent...but alas my days of getting there at 5am are limited...although I plan to go to one this weekend!
Steve...if you want to pop over to the workshop with the infill I will give you my thoughts....I'm only at Wrotham Heath junction M20/M26
Jimi
Jimi
that would be a good chance to get it working
theres something not quite right with it
Steve
I saw a Norris 50 at my local auction.
It was cracked right through the cheek and had been brazed, messily.
The braze repair had broken.
As seen at the auction, it was repaired with Gaffer tape!!
BugBear
BugBear
did u buy it ? :)
Steve
BugBear
did u buy it ? :)
Steve
Nah, I've got enough gaffer tape.
BugBear
