"Tip and Spur" and "Brad point" drill bits ?
OldWood
1 Mar 2005
Edinburgh
I've had to seek guidance on a drill break out problem (drilling holes in to a spherical surface). Suggested solutions include using a tip and spur bit, but then someone else suggests a brad point bit. Are these the same thing ?
Rob
dunbarhamlin
8 Jan 2007
West Cornforth
Hi Rob
Yes, as I understand it, "Brad Point" is just North American for "Lip and Spur."
With a steady hand and a grinder, you can make your own from normal twist bits - I believe the super Veritas "Brad Point" bits start out life as normal twist bits.
Steve
kirkpoore1
3 Nov 2010
O'Fallon, Illinois
dunbarhamlin":j07gryjp said:
Hi Rob
Steve
Yes, they're not hard to make. But you need to get a thin reinforced abrasive cutoff wheel to do it, such as a Norton A60OBNA2. A magnifying glass clamped to the eyeshield helps too.
Kirk
Spindle
7 Aug 2011
Aberdeenshire
Hi
Re grinding standard drills is good for those of us with the ability, (not me :( ), a top quality L&S bit will cost less than a tenner, my advice would be to invest in one and then form your own opinion as to whether you want to buy more, (I did :) ).
Regards Mick
kirkpoore1
3 Nov 2010
O'Fallon, Illinois
Spindle":3medxhij said:
Hi
Regards Mick
That's what I did--bought one from Lee Valley. It worked well, so I got the cutoff wheel for about $10 and a friend showed me how to sharpen, then I started digging old dull bits out of dusty tray I'd stashed away. Whenever I need one now, I find an old bit and spend about 5 minutes reshaping the tip.
Kirk
kirkpoore1
3 Nov 2010
O'Fallon, Illinois
Spindle":zk70zjm2 said:
Hi
Any chance of a tutorial or link :D
Regards Mick
I've been looking but haven't found anything on line yet. (Might be something on youtube, but I can't search there from work.) I saw a demonstration in person, so I don't have a link.
Kirk
monkeybiter
23 Dec 2009
doncaster
If you drilled a clean hole of the desired size through a flat piece of hardwood or plastic and then clamped this tight to the spherical surface you could use it as a drill guide and it should prevent breakout. IMHO
OldWood
1 Mar 2005
Edinburgh
I'm going to try avoiding that as it has all sorts of difficulties - shape, clamping, aligning and the time to do all that; I know it's a recognised procedure but it has its limitations and I'm hoping the tip and spur drills will be the answer.
Rob
Von Ryan
4 Oct 2011
Herts
I get lip and spur bits from Isaac Lords,yellow pack, German bits called Famag. Tip top. The right size exactly!
