Wood Monkey
Hi All
My mum came round last sunday and said "can you make me a lamp table? The measurements are 22 inches high and 9 inches square and I'd like a shelf to put the phone on.". The first word that entered my head was 'topple'.
Basically, there is a small gap next to her sofa and she wants to put a lamp on it with room for her reading glasses and a shelf for the phone. She already has some Oak furniture. As design briefs go, I guess it's sufficient - topple- sorry, I can't get it out of my head.
I came up with this. I scaled it on sketchup and it looks OK on the screen so I guess I'll make it. Topple, sorry.
The small size means I can raid the scraps bin. Step 1 was to make the legs and after a quick Google I decided to make them on the jointer (any excuse, it's new). One softwood practice and then straight in to 4 legs ripped out of a 30mm thick piece of Oak and dimensioned down to 25x25mm and then tapered by affixing a small spacer to one end and then passing over the blades (6 times to be exact. The small end of the taper now measured 10mm sq.
Another rummage in the scraps bin and a nice piece of quarter sawn was dimensioned down to 15mm using the jointer and the thicknesser and this will then be ripped down to make the rails (is this the correct terminology?).
I thought about biscuit joints but the rails would need to be too deep so I decided that I'll go with either some cut down biscuits (loose tenons) or real tenons. First cut for the mortices was made using a portion of the biscuit jointer blade. (The first person who tells me I need a Domino wins a bag of sawdust as I already know I 'need' one ;-)
..... and finished with my smallest LN chisel and my Blue Spruce dovetail chisels as they have such a slim profile the full length of the steel. They are cut all the way to the top to maximise glue area.
Blue Spruce 12mm on the left and LN 12mm on the right.
So this is as far as i've got (mortice clean-up not completed). About 2 hours work so far.
More to follow shortly, but let's finish with a quiz.
Q1. Will it topple over (I've a plan to stop it, bonus point if you can guess what that is)?
Q2. Will the joints be strong enough or do i 'need' a Domino, really, really, really 'need' a Domino (actually, I've a plan to make them stronger)?
Jon
Jon
