timber
user 19915
25 Jun 2014
Is there any way i can store my timber with out it warping mostly 4 x 2 and other soft wood,s ??/
Hi Mock,
If you have room, build a small waterproof shelter. It doesn't have to be a walk-in shed. Side it with spaced vertical 3 x 1 timber, each side of 2 x 2 pressure treated framework. Store your timber in that, and 'in stick'. The air can get to it and circulate around it. Bring stuff into your shop a week or so in advance of starting a job. Even then the cheaper materials you buy might bow or warp. Use this stuff asap after buying, for the 'run of the mill' jobs. I keep twisted and bowed timber for the shorter lengths of a job.
I don't buy timber to store any more. I buy as I need it and acclimatise it on trestles, in the shop.
HTH
Thank,s yes iv,e got my timber all stacked in the garage some that the air can not circulate I,ll have to put spacer,s between them for the time being
thank,s mock
