Timber for roof finial
Nelly111s
1 Jul 2017
Preston, Lancs
I've been asked to make a roof finial. Dimensions overall are 1500mm long, 120mm square. It consists of a spike of 600mm and a 900 square section with turned ball. The construction should be straightforward, but Im not sure what the "best" timber for this would be. Clearly it's the sort of thing that will get little maintenance and some form of hardwood would give the longevity.
So, two questions really,
  1. which species?
  2. if this species is only available in section less than 120mm which I suspect is likely, is D4 glue the best to laminate 4 or 9 pieces to get the required section?
johnnyb
13 Nov 2006
Biddulph staffs
I used redwood soaked in preserver. it was glued up I think. the biggest thing was putting it on the roof as it needed ladders off the top level of scaffolding....gulp.
johnnyb
13 Nov 2006
Biddulph staffs
here it is being turned. and a photo showing the rot at the back. we replaced lots of other timber bits using accoya.
Nelly111s
1 Jul 2017
Preston, Lancs
Thanks @johnnyb. Any idea on the expected lifespan of the redwood? The current one has been on the roof for tens of years, may 100, so I need something that will last a minimum of 10 years ...
That finial looks similar to the one I've got to copy, although the "spike" is faceted rather than round (which would be easier and may be suggested to the customer!)
johnnyb
13 Nov 2006
Biddulph staffs
my aim is always the clearance time of a cheque.
the previous one was redwood. it lasted from 1907. its rotted because lazy painters didn't paint the bit you cannot see around the back. this obviously gets wet but also dries. maintenance is vital with all wood. oak wouldn't be my goto for this as it doesn't really take paint to well sapele may be better. iroko doesn't paint so well. maybe southern yellow pine or douglas fir. my choice would be a single chunk( if I had one)
johnnyb
13 Nov 2006
Biddulph staffs
a faceted finial would be interesting. at least you wouldn't be planing against the grain! my lathe does have an index wheel that would make marking out a doddle. the rest would be hard graft.whose gonna notice up there?
Nelly111s
1 Jul 2017
Preston, Lancs
I doubt anyone would notice. My lathe also has an indexer, but I did think I may be better making it out of six staves using a jig on the thicknesser. Not sure which would be easier / better. Depends if I can get suitable timber in the right cross-section.
Nelly111s
1 Jul 2017
Preston, Lancs
Definitely Accoya if I was doing it.
I've never used Accoya. Does it turn OK (for the ball at the end)?
Also, is it widely available - I'm in NW England and not seen it in any local merchants (but maybe not looked hard enough either).
Cabinetman
5 Jan 2017
lincolnshire Wolds
I used it to turn a couple of finials once, turned well but the shavings stuck to everything including me, with static in a very peculiar manner.
From memory it’s guaranteed 25 years underground and 50 above. Ian
Jones
5 Oct 2021
Gwynedd
Standard reds will be available in the size needed and easy to turn. If you can send it back to the merchant and have them put it in their preservative tank it will last as well.
Bob Chapman
23 Apr 2007
West Yorkshire
When I had my business I made dozens of replacement roof finials. The ones being replaced were mostly Victorian and mostly pitch pine. I also used reclaimed pitch pine from a firm a few miles away and never had any problems. No reason why they shouldn't last another 100 years or so.
