Timber Concertina Doors
Kev
12 Nov 2004
Kent
Help :(
Wondered if anyone has tried this before or can point me in the right direction. I am planning to replace the aluminium sliding doors in my dining room which go into the back garden this summer. The opening is just over 3.5m wide and about 2.5m high. I am planning (obviously) to build them myself in timber maybe having 5 (may be 4 or 6?) narrow doors that concertina back when opened. Information on how to achieve this seems a bit sketchy. Doing a quick web search, most of companies that offer a full service (supply and fit) all seem to use inset tracks that the doors run along and serious hinges to hold them together. Is this the best way? and if so is this type of ironmongery readily available? Would appreciate any help!
radicalwood
18 Nov 2004
birmingham
Hi Kev.
Not had any experience of this, but I think that you do need the tracks top and bottom to help the doors track and fold in the correct manner. I also think that they will use the track as a means to stop water entering the hose and also for fitting security devices into to stop the doors being forced open too easily. If you making the yourself the security is paramount. not even sure where to look on the web.
all the best
Neil
tim
5 Nov 2004
Herefordshire
Kev,
If you look at the Hafele website (www.hafele.co.uk) they have more of this stuff under their architectural ironmongery section than you can shake a stick at.
As Neil says security is a big issue plus you will need to check whether any alterations you are making comply with Building regs in respect of ventilation and thermal efficiency.
Tim
Kev
12 Nov 2004
Kent
thanks for the web address and advice. Have emailed them to see what they say. Will hopefully be able to post some pictures in the summer when they are up!
Les Mahon
7 Oct 2004
Cork, Ireland
Kev,
You need also to check youe insurance, not sure what it's like thre but here some insurance companies are very sticky about types of locks etc.
Les
