I have got this motor and would like to know if it is possible to get it to single phase ,if not what power would I need to be able to drill around 40mm forstner bits , and are the machine mart motors ok.
Thanks.
Clive.
Thanks.
Clive.
Yes good advice, you will get a better quality motor for probably less money.Ignore Machine Mart. Buy a TEC brand motor
A lot of these people think they want something that they really do not need, ie fully variable speed on a pillar drill using a VFD. My Atlas has the six steped pulleys to change speed, 90% of the time it runs 2200 RPM, I drop it right down if using a large morse taper drill bit or a flycutter. The reason they use a VFD is because they take a big risk and buy cheap so it appears cost effective, in reality a decent VFD is about £200 but that has full protection features and will not burn your workshop down, have seen too many incidents in my time because people cut corners, buy cheap products and then are not qualified to undertake electrical design and installation and then fail to undertake final testing to confirm everything is ok, because too many think if it works it is ok.I am thoroughly sick and tired of home made motor replacements. Usually they end up with a motor that really doesn't fit in all dimensions and conclude that the machine is worthless to people like me...... who then struggle to find a motor that actually works.
I agree entirely that if you don't know what you are doing them messing with electrics is a bad idea, however I think you are a bit harsh in your view of vfds. As an example I have a Harrison lathe. Came with a 1.5 hp 1400 rpm 3phase motor, giving a top speed of 750 rpm. The machine is rated up to 2000 rpm. So I fitted a 2800 rpm 3hp motor running at 240v 3 phase. I have set up the vfd so it gives two speed ranges, 1400 rpm and the full 2800 rpm. I use the machines own 8 speed gearbox to vary the speed within each range, but now have 16 rather than the original 8 speeds, and a maximum of 1500 rpm. Courtesy of the vfd I also have soft start and jog facilities, both very useful as is the emergency stop. The vfd is a Huan Yang rated for up to 4hp and costing £130. I now have three of these running different machines, and have never had a problem with any of them. The same machine has a second small vfd running the coolant pump, in this case via a pot, so I can vary the speed, and coolant delivery, by just turning a knob. So they can be extremely useful, an enable you to retain the much smoother three phase motor on your old machine. This may not be quite so important on woodworking machinery, but certainly makes a difference on a metalworking lathe or mill.A lot of these people think they want something that they really do not need, ie fully variable speed on a pillar drill using a VFD. My Atlas has the six steped pulleys to change speed, 90% of the time it runs 2200 RPM, I drop it right down if using a large morse taper drill bit or a flycutter. The reason they use a VFD is because they take a big risk and buy cheap so it appears cost effective, in reality a decent VFD is about £200 but that has full protection features and will not burn your workshop down, have seen too many incidents in my time because people cut corners, buy cheap products and then are not qualified to undertake electrical design and installation and then fail to undertake final testing to confirm everything is ok, because too many think if it works it is ok.
