Thread Cutting
UKTony
12 Nov 2004
Stevenage
I was watching a Video on box making for the novice, all the boxes look simple - ish to make however all the lids were push fitted, do you have to buy a special jig to do threads or can they be done by hand, if so which one is recommended
Tony
TOny
Push fitted lids - thread cutting?
I am confiused.
To cut small threads use a tap and die set
For large threads a lathe with a mechanical feed - metal turning lathe
Might be able to cut threads on a wood lathe but I would GUESS that you need a jig of some sort
UKTony,
Slow down a bit, learn to turn before you even think of looking at threads. There's a whole world of other skills you should consider first. Good suction fit lids on boxes are challenging enough, try these first.
Tony:
Threads can be cut on a woodturning lathe using hand held tools, these are bought with different pitched teeth, one tool each for the male and femal. Only very and dense woods will take a clean thread and only a few turners can do it well.
Regards....Mike
Hello Tony,
Regards....Mike
Cutting Crew":2ncvnofv said:
UKTony,
Mike
More an inquisitive question rather than an attempt, will have a go at a box this week once i've tried a few egg cups/goblets...looks like the rest of my woodwork is takking a back seat :lol:
Hi UKTony,
I'm not surprised your 'normal' woodwork is getting neglected, I found learning to turn wood so absorbing that I ignored my table saw for months.
You have just missed it for this year, but the Woodworking and Turning show at Stoneleigh (October) has a number of demonstrations going on that you can watch and talk to the experts. I saw a demo of box making with screw tops and it was awesome.
Good luck with the egg cups and goblets
Wulf
