transatlantic
Boom!
Has anyone had any luck making a Thien Baffle type system for a Cam Vac (Twin Motor)?
I've been experimenting with something like this :
With only one motor enabled, it kind of works, but I want the extra power of two motors as I want to use it with my thicknesser. With two motors enabled, I get two issues :
1) The barrel collapses. Note, this isn't due to a blockage! it collapses with no blockage. So I am guessing here that the inlets are just too small? and it's an air flow issue? air is being sucked out of the barrel quicker than it can enter? ... both inlet and outlet are the same size pipe (50mm), so not sure about that theory.
2) Strengthening the barrel for the above issue (not a solution I know, but I wanted to experiment), and trying again. The Camvac is so strong, it sucks up anything collected at the bottom of the barrel.
Am I going to be able to get this working with 50mm pipework? I don't really want something that has 100mm pipes. I know that 100mm cyclones like the Axmintser craft ones exist, but I wanted this to be somewhat portable.
