The Perfect Router
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
OK guys and gals,
Let's play at design by committee. My Perfect Router would be/have
1. Tool-less cutter change.
2. Built-in Router Raizer, but not vulnerable to debris entering the body when in table mode.
3. Easy, positive switch.
4. Plenty of power for panel-raising,
5. But not too heavy for free-hand work.
6. Built-in dust extraction that doesn't impair the view of the cutting zone
7. Can be stood upside-down o the bench without the cable getting in the way.
8. Be accurately concentric, shaft to base.
9. Easy to attach bushes etc.
10. Easy to fit homemade subbases, without having to modify the base first.
THere, that's my ha'p'orth. Your turn.
CHeers
Steve
Chris Knight
14 Jan 2004
SE London - NW Kent
Add a decent plunge to say 10-15mm below the base, to compensate for router table thickness.
A first class fence - think Microfence.
A supplied eccentric sub-base (the usual tear-drop shape) that clips bayonet fashion - think Bosch guide bushes - to the router without the need for screws.
SlimShavings
25 Dec 2004
Tennssee, USA
HAte to say it but this all sounds a lot like a shaper to me :lol: :lol:
Since you don't use dado's , maybe you 've never done free hand shaping on a shaper either :? :?
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Bosch type click on template guide mounting rather than messing about with 2 dopey slotted screws.
MikeW
15 Apr 2005
Forest Grove, Oregon USA
Well, someone had to do it...
Alf
22 Oct 2003
Up the proverbial creek
And there I was being good... (and don't think that #67's a gloat. Mine's older than that and having a Millers Falls in this country is a much bigger gloat :p :lol: )
Cheers, Alf
