Off we go then.
Seeings it's a good day to start the ball rolling, I've made a move on starting the carving of the first part of the vault, which is the tas de charge or springer.
This piece is where the spring of the vault starts curving up towards the flat spandrel. It has a single curvature that rotates around the central axis to make the conoid shape for the fan.
I have turned the basic form from a single piece of oak. The ribs will be made seperately and then tennoned into the shaft with a straight joint at their connection point with the top of the springer.
It's about 17" long and 6" diameter at its widest point. Here it is roughed out and I'll carve the lot of them, 6 in all, before I finish the details. I can't put the moulding on the ribs until I've decided on its profile, which will be when I make the ribs, so there's a bit of backwards and forwards, but I know its width and depth.
At the bottom of the springer there will be a carved and gilded foliate boss, which will be attached by a socket and spigot or threaded joint. That's where the vault will stop at its lowest point as it's going to hang from the ceiling.
The ribs go from nine to three with a fancy overlapping gothic arch form, containing a cusped cove detail. You'll have to bear with me on that, as I'm still working out how I want it and I'm now designing and making on the hoof, as I'm drawn out and don't feel like doing lots of projections.
I set the ribs out on the lathe, as this had a handy reference point ( the bed) and I could rotate the springer around its central axis and step off the 16 ribs, 7 of which will be cut off, as they won't be used.
I'll cover the setting out another time, as I need to take the photos first, but it was fairly straightforward to do.
The shaft at the top of the springer gets a lap dovetail cut into it, which will fit into the oak frame from which the vault will hang.
It might not look much at the moment, but it has taken a few weeks to figure it all out and it needs to work first time as the whole vault will sit on top of it and it determines the form of the vault.
I found some 8" x 6" air dried oak that had been drying for 15 years in the shed and it carves like silk, beautiful wood and a joy to work with.
