Bluekingfisher
Despite having an insulated and dry workshop and keeping my cast iron tools waxed and well oiled I noticed while pottering around last Saturday most of my cast iron tools were 'sweating' from I can only assume the abrupt temperature change. I was initially a little concerned but as I have had my present set up for 5 - 6 years I have never suffered from condensation or rust so assumed the issue would only be temporary and normal.
However, I had cause to visit the workshop last night and found to my horror a great deal of my tools have turned poop brown. I had a go at removing it from the worst affected tools however it took a little more than gentle elbow grease to remove the rust from the one of two tools I attempted to clean up.
I only mention this as this has never happened to me previously and perhaps those of you with cast iron tools may wish to check on them sooner rather than later, particularly if you haven't seen them for a while or your shop is not well insulated.
Good luck
David
Good luck
David
