Tenons with the router
JFC
30 Sep 2005
London
Im making a couple of oak doors as a fill in job and having seen on here a lot of you do your tenons with the router so i thought id give it a go . Ive cut the cheeks on the tenons first to stop any breakout and have put a planer cutter in the router on my Record R PMS-R router table . I found it quite a lot of work and had to do alot of passes first at half thickness then full thickness. I thought about cutting more grooves into the tenon on the cross cut saw first to ease the work of the router, then i thought ill get on with the mortices and ask the experts on the forum :lol:
Also i always seem to have trouble with chipping when i am moulding the ovolo and rebates no matter what timber i am using , i've found marking the timber with a marking gauge stops or at least reduces it on most timbers but AWO seems to chip no matter what . Any tips ?
JFC
30 Sep 2005
London
Im back on the oak doors tomorrow and i've got to scribe the ovolo mould into the styles to make the tenon fit flush , i normally mark off the start of the ovolo cut at 45* and use a carving chisel to get the same shape . Anyone got any tips or a better way to do this as i don't think this is the best way .
tim
5 Nov 2004
Herefordshire
Either mitre both corners so that the pattern joins or, much easier and quicker get a matched cutter set and run the rails and stiles along the inverted cutter using a spelch block on the end grain.
Tim
JFC
30 Sep 2005
London
Its only an ovolo mould so a concaved cutter would do that i think , any ideas for a jig to hold the router level or would you do it on the router table ?
tim
5 Nov 2004
Herefordshire
I'd definitely do it with a router table - depending on the size of doors you are talking about. If they are huge, then I'd use the router free hand.
Tim
SketchUp Guru
12 Apr 2005
Rochester, MN USA
I think Tim came up with the same idea I had but I was busy making you a picture. Here it is.
If you haven't cut the profile yet, you might be able to find a matched set of router bits to profile the ends with.
JFC
30 Sep 2005
London
There a standard size door ( ish) think ill try it on a scrap piece first rather than risk all the work i've done already on them .
Thanks for the tip , i've not been on this forum long and im trying and finding better ways to do things every day :D
JFC
30 Sep 2005
London
Ive tried the mitre way before and although the finish is nice i found it hard to mark out the 45* on the ovolo , its ok for the styles that are 100mm wide but the bottom and mid rails wont fit under my radial arm saw so need to be done by hand . Ive been looking for a jig or saw guide that will help me with this but cant seem to find one .
JFC
30 Sep 2005
London
Scott thanks for the link its inspired me to make my own jig that will slot over the 45mm PAR with an internal mitre cut to guide a fine saw . Now why didn't i make one of these years ago :roll:
j
27 Sep 2005
Milton Keynes
Dave,
Nice diagram, Makes things very clear.
Which program did you use to make that?
J
SketchUp Guru
12 Apr 2005
Rochester, MN USA
J, thank you. The program is called SketchUp. It was developed as an Architectural sketching program and isn't technically CAD. I find it very useful for doing shop drawings and making illustrations such as this one.
