So I've been designing my workbench, and have decided to tackle mortise and tenons. I originally designed the base stretchers with a 50 x 100mm stock, obviously it's going to come in at 48mm x 100mm, which is fine, I can make those adjustments - but I just wanted some advice on the size of the tenon's. I'm also going to be doing it as a through tenon - so they will be 48mm long, and I had them at 22mm wide and 72mm high, does that feel too much?
I know about the thirds thing, and it's just a rule of thumb, but this should still work fine right?
