enterthedragon
is it true that alot of tenon saw plate is glued into the back? wouldnt that make removing the back impossible? how would u clean a rusty saw then?
no.enterthedragon":7q0ero7b said:is it true that alot of tenon saw plate is glued into the back?
BugBearwouldnt that make removing the back impossible? how would u clean a rusty saw then?
Disagree with bugbear here:enterthedragon":3rv78o1u said:is it true that alot of tenon saw plate is glued into the back?
Can only speak for our saws: No. But it is hard work and you have a very good chance (70%) to destroy the blade. We use Locktite and that is not heat resistant. But the blades are, neither.enterthedragon":3rv78o1u said:wouldnt that make removing the back impossible?
When I clean a backsaw I allways try not to remove the spine. Because you have good chance (20%) to destroy the spine doing this. Just use a triangular block of wood with sharp edges and some fine grit sand paper.enterthedragon":3rv78o1u said:how would u clean a rusty saw then?
Since the question was about restoring/cleaning, I assumed the OP was talking about old saws, and he did say "alot"pedder":m8lhamsq said:Disagree with bugbear here:enterthedragon":m8lhamsq said:is it true that alot of tenon saw plate is glued into the back?
Many modern maker do this: Lie-Nielsen, Adria, Wenzloff & Sons on some of their saws, Veritas, and we. Don't know exactly about hte others. And I've found at least one semi old Tyzack saws with glued blades.
I've never remobved a spine.pedder":1ys8eang said:Hi Paul
the more important point was: Better do not remove the spine wether you can or can't. I've done that in the past and some nice saws lost their virginity. Two Disstons (one with a brass back) and a Spear & Jackson. If that happens you can use Locktite or A hammer.
Pedder
only every other tooth is hard to clean...bugbear":1nka1ggy said:Cleaning near the teeth is harder
:lol: :lol: :lol:pedder":26dzklmo said:only every other tooth is hard to clean...bugbear":26dzklmo said:Cleaning near the teeth is harder
