A
Anonymous
Guest
Hi all
I have a problem with a potential project and so am turning to some knowledgeable friends for help :wink:
Basically, my telescope is too big and too heavy to store in the upstairs study and carry down for observing. Thus, it is not used as much as I would like.
I have a solution. Build an airtight (dust tight) cupboard in my workshop/garage!! I could make it ceiling height and store tools etc. in the top non-airtight sections too
Simple you might say.
Here is the problem. How to make the airtight door?
I guess the cupboard will be 18mm MDF, possibly attached to a frame of some sort. I can seal the cupboard door with some foam or rubber tape from B&Q. But, what should I make the door from and how?
It needs to be rigid and not twist so that I get a good seal - but not too heavy. I think MDF on it's own will not have sufficient torsional stiffness.
The lower (telescope) storage bit would be about 1m deep (front to back) about 0.5m wide and about 1.5m tall
any advice?
any advice?
