Tapering tool
colinc
30 Nov 2003
South Derbyshire, UK
Hi,
Am not really sure of its proper name, but it’s for tapering the mortises for round tapered tenons. Works fine but I inadvertently ground the blade the wrong way so I have to rotate it anti-clockwise.
Next task is a taper rounding plane to match.
Colin
Trainee neophyte
12 Apr 2019
Greece
Which ties in with your tapered dowels. You appear to be planning to make something exciting.
colinc
30 Nov 2003
Woody2Shoes":1n3dr82b said:
Tapered reamer?
Looks nice, what materials did you use?
Cheers, W2S
The body is what I think is iroko. It was the mantle piece of a fireplace I took out a while ago. The handle is a scrap of oak. The blade is a machine hacksaw blade that I bought for £1, wish I could find more of the same as it is very good steel. Total cost, next to nothing.
Colin
colinc
30 Nov 2003
I am planning to try my hand at chair-making. I was planning to do a course around now, but circumstances make it hard to take a week out at the moment, so I am taking a teach myself approach and making some appropriate tools and fixtures.
Regards,
Colin
colinc
30 Nov 2003
Pete,
I was thinking upon similar lines. The postman delivered a couple of Veritas tendon cutter blades today and I was planning to make a wooden tenon cutter to match the reamer over the weekend.
That stool is really nice, I have been collecting pictures and ideas as my daughter could use a couple to replace her Ikea ones in the kitchen. I need to source something wide (and expendable) for the seats, I do have a couple of really good wide pieces of timber that I have been saving for years but am not yet confident enough to commit to using them on a learning exercise.
Regards,
Colin
Racers
22 Apr 2005
Hi Colin
Glue up some softwood and have a go at making the seat, thats what I did.
Once I had made the seats I knocked up a simple open framework so I could use broom handles to work out the angles and positions of the legs.
The stretcher angles can be worked out by fitting the legs and stretching elastic bands across, then set a bevel gauge to the same angle.
I made a pair of the stools, they are good fun to make, I didn't use a lathe just drawknives spokeshaves etc.
My taper is to steep I should have gone for a lower angle, it took ages to cut the taper in the rounder.
I have used it on these occasional table for the decking.
Occasional table by Racers, on Flickr
It only took me 2 hours to make one, I used branches from my apple tree for the legs and stretchers.
colinc
30 Nov 2003
Pete,
Thanks for the encouragement.
I acquired some wide boards of Ash and Cedar yesterday that will make some seats. I have some kiln dried Ash for legs, but also three 4ft Ash logs from a local firewood yard that I will split rough out and put aside to dry for use in the future.
I started making a taper tenon cutter yesterday and will finish it today assuming the lights stay, we have a couple of power interruptions due to the wind already.
Regards,
Colin
colinc
30 Nov 2003
I made a taper tenon cutter to match the reamer today. It works pretty well. Also made 2 of 3 legs for a simple side table. I made the basic taper blanks on my simple router lathe then transferred to the lathe to sand them and turn the parallel tenons. Doing that makes them very repeatable.
Colin
colinc
30 Nov 2003
Got to try it out today. I did have to open up the entry hole a little and refine the curve on the blade at that point, but it works....
Colin
