gasman
'Morning all
Its been a long long time since I did a work in progress on UKW but I have wanted for a long time to make a tambour cabinet / sideboard for our home...
I wrote to Richard Jones of this parish who made the Torpedore cabinet which I admired for a very long time and kept returning to. He very kindly replied with encouraging words and advice but I then found Poritz Studios over in New York State who make amazing tambour-based furniture with the tambour slats on the outside of the piece rather than the inside. This is the piece which I saw and had the 'wow' factor I wanted...
I made a writing slope recently which had a tambour section concealing where the pens are kept which helped get the concept of small tambour slats and how to make them slide easily
So I have designed a sideboard with design elements of both Richard Jones' and Poritz's cabinets in it.
Here is my rough design sketch showing where I have got so far
The tambour slats will be made from 9mm marine ply with Spanish walnut veneer on the outside and ABW walnut veneer on the inside making them about 10.5mm thick. Each slat will be 15 or so mm wide and about 450mm long on a canvas backing. They will run top and bottom on a 3mm wide brass strip which will run in a 3mm wide groove cut into the top of the slats. The brass strip will be glued into a 3mm slot cut into the top and bottom of the cabinet. The whole of the top and bottom will be ABW with the interior - drawers and cupboard sections - in maple.
Although the membership of this site has changed considerably since the days 10 or so years ago when I did regular WIPs, I still find this site immensely valuable for the insight and advice which the members give. I feel this project is going to generate some tricky problems to solve so I am looking forward to your wise counsel. Thanks guys. Mark
