Tablsaw extension.
Paul.J
27 Sep 2006
Birmingham/England.
I bought this Kity Best combi from a fellow member not so long ago,but the tablesaw bed i felt was too small.
So decided to add my own extension table to it.
It was an old cooker door that we had,the cooker came damaged so the door was replaced,i kept the old one which has now been used for this.
I can now get a 20" cut by moving the guide rail,but does anyone know if i can get the longer rail that holds the fence.I know Kity have finished and parts are sparse but is there any way of extending the rail??
I think there may be 2 options for a longer fence. One is the axi longer rails with extension table.
http://www.axminster.co.uk/axminster-ax ... rod825727/
Or depending on the profile size of the existing rail? Some steel box section such as this
http://www.ebay.co.uk/itm/MILD-STEEL-BO ... 1c22c26f45
There are quite a few steel stock holders in brum that could sell you a length to your size required.
If you want, i have the original short rail from my axi ts200 if you want to see how the profile compares to your kity one? :)
Thanks Carlb.
Here is a profile piccy of what is on the saw now.
I think the Axy one will be too big,which is more suited to the Kity 419,this is a lot smaller about an inch square but will check that.
The slot on the bottom slips under two bolt heads which are then tightened.
I suppose i could try making one out of wood,but i think it will be too small for any strength??
Ahhh yes that is a completely different profile to the axi one. Doubt your fence would fit the rail.
