PJ
After reading the posts lately about new tablesaws it has prompted me to view a couple. I have looked at the Fox with sliding carriage and the Sip with cast iron top. Not much more over here in Northern Ireland to look at apart from the Jet and Scheppach models which are probably outside my budget
Anyway of the two I came away thinking the SIP is ahead with a smoother adjustments and a more solid fence. My only concern is the blade used, It is a thinner kerf than standard with a 25.4mm bore and the machine only spins at 3500rpm.
Do any members use one of these saws and if so do you notice the slower speed.
Any info??
Many thanks
Philip
Ps. I have no requirement for a dado blade, possibly in the radial arm but not in the table saw
Any info??
Many thanks
Philip
