user 19915
- Joined
- 25 Jun 2014
- Messages
- 1,471
- Reaction score
- 11
just a quick question should the table saw riving knife be the same highs as the blade or above or below ??? better safe than sorry
ALAN
ALAN
Steve Maskery":24a2xwil said:Obviously if you are making any kind of a non-through cut, then it must be fractionally below the top of the cut, otherwise the wood will hit it. (This practice, although historically commonplace, is no longer approved by the HSE, I believe)
Wizard9999":ns6gk26j said:I have always puzzled as to whether there is actual benefit to having a riving knife in place, would be interested in our and the thoughts of other experts.
Wizard9999":ns6gk26j said:As an aside, I think we have the same saw (older model Xcalibur) and I wondered if you have any idea on a source of spare parts. Buying a riving knife and cutting it down is the easiest way I can think of ending up with a shorter riving knife.
Steve Maskery":3gc2nh3o said:Obviously if you are making any kind of a non-through cut, then it must be fractionally below the top of the cut, otherwise the wood will hit it. (This practice, although historically commonplace, is no longer approved by the HSE, I believe)
The answer really is ... it depends on the riving knife and blade configuration. In some saws the riving knife has the crown guard attached to it, e.g., the Hammer brand (Felder's lesser offerings), meaning the riving knife must sit higher than the blade in order to hold the crown guard. In the case of other manufacturers, e.g., Altendorf, the crown guard mounts on a separate arm, and the riving knife is set to just a hair below the tangent of the circle described by the rotating blade. So, again, it depends on what type of saw you have, and how the riving knife and crown guard are configured, and also depends on how closely you wish to follow HSE recommendations for safe table saw use. Slainte.mock":2c01itjz said:just a quick question should the table saw riving knife be the same highs as the blade or above or below ??? better safe than sorry
ALAN
Steve Maskery":1i3j6fx2 said:Wizard9999":1i3j6fx2 said:I have always puzzled as to whether there is actual benefit to having a riving knife in place, would be interested in our and the thoughts of other experts.
Terry, I don't want to sound rude, I really don't, but if you don't understand the importance of a RK then you should not yet be using your tablesaw. Get some proper training. You are almost certainly putting yourself at unnecessary risk in the way you are working. Short fences for ripping, pushsticks, featherboards. The RK is just one of an armoury of bits and pieces which help to keep me safe at my saw..
Steve Maskery":4ltjovn3 said:Ah, OK, I see. Fair enough.
Right, so why use a RK for non-through cuts? Well if the cut is shallow, I don't suppose it is doing anything at all, really. But if you were doing a non-through cut at full height, 3" say, (and that would scare me a bit, if I'm honest) I suggest that there would still be the possibility of the wood closing up on the RK at table level. As Robin has said, it is quite common for wood to close up on the RK (which is why we have them in the first place) or spring apart, pushing the workpiece away from the fence and into the blade (which is why we use a short fence for ripping).
