Table saw for built-in workbench
rockwing
New member
13 Nov 2019
Hampshire
I'm planning to build a workbench on castors for my garage to incorporate a table. I'm only a hobbyist so do not need anything too high-end, but would require:
- Fully retractable blade (for a full-flat worktop)
- Ideally no dust-hose out the back so I can push through longish sheets of wood (will have a shop-vac in the bench.
- Cutting depth up to 50mm
MikeG.
24 Aug 2008
Essex/ Suffolk border
I really advise strongly against this. It's cropped up here before. You'll end up with an un-usable bench, and a table saw which requires the bench to be cleared every time you want to use it. That simply isn't practical in a workshop.
sunnybob
wysiwyg
11 Oct 2014
cyprus
The closest youll get is a contractors saw.
I have the dewalt 745. Its a really good saw with a first class fence. The blade will fully retract to give you a medium sized work bench.
Lonsdale73
21 Feb 2015
County Durham
Have a look at this idea. He uses a saw like sunnybob's (I have the same saw too) which uses the bench as an outfield table and is out of the way when you want to use the bench for other tasks. For a while, I had a tablesaw at one end of the bench, at 90 degrees so I had the whole of its length as an out feed table.
