Loosen the bolts either holding the table on or depending on design, the bolts holding the saw mechanism on and adjust the blade to the mitre slot NOT the fence. Once the mitre slot is set correctly with respect to the blade, only then adjust the fence either dead on parallel or with slight toe out away from the blade which some people advocate. Never any toe in.
