Table game
pbr1983
New member
7 Apr 2020
Wales
Hi all,
I have a joinery project in my head, but I'm having problems selecting the main material.
It's a table top game, probably 2' x 3' in size, and the board its played on needs to be a) completely flat b) no thicker than half an inch or so, and c) decorative (ie probably not plywood - at least the ply in our local store!)
It's final finish will be like a polished mahogany, but I'm presuming a base that size in half inch mahog would warp over time
All suggestions welcome!
Droogs
Is that chisel shar ... Ow
14 Mar 2013
Edinburgh
You could use 12mm MRMDF and then veneer with a decorative wood as you see fit and a cheaper balance veneer on the rear
sunnybob
wysiwyg
11 Oct 2014
cyprus
12 mm ply would be lighter than mdf, and possibly cheaper.
Make sure one face is baltic birch though. It will stain quite well if you really want a mahogany finish.
gasman
14 Nov 2006
Near Oxford
Use grain filler before your final finish goes on - I use the Rustin one which is only a fiver or so - the mahogany one makes a huge difference I find to the finish one can get on dark woods
I would go with MDF though - and then veneer both sides
Mark
