Lonsdale73
Looking for a good, reliable and well, square t-square - any suggestions?
lurker":3t1mhlm2 said:Welcome to the forum by the way
Hope you stick around we are a friendly bunch!
It almost certainly won't be the squares at fault. It'll be procedural.Lonsdale73":13q6i90g said:"... you aim at accuracy of course, but if you apply engineering standards you will be endlessly dissatisfied - many things don't last overnight staying the same length, or flat."
I appreciate I might be pedantic way beyond my technical ability. I have three carpenter's squares which appear square to one another and feel it would be a remarkable coincidence if they were all out by the same amount. Referring back to the frame example, I assembled one long and one short side together, placed one square on the outside, one on the inside and all seemed fine. Repeated it for the other two lengths, again all seemed fine. When joining them together, I could get one corner square but not the other, ending up with a kind of trapezoid. Baffled.
The problem, whatever it is, will be simple. Something isn't square, or something is shifting the workpiece out of line, or something. It should be possible to spot it by looking closely and maybe it will just need a bit of a shim somewhere, or a tap with a hammer. Getting the kit working properly is all part of the process especially with cheap kit (Charnwood). It won't necessarily work properly out of the box.Lonsdale73":t602ht0c said:... I'm continually checking the rip fence is square and parallel but if I draw what I believe is a straight line on the piece to be cut then the cut itself doesn't run parallel to the line. ......what the problem is.
This is true - they are all craft skills (including music which is my latest preoccupation) and this includes getting the kit to work long after it's outa the box.lurker":ry5f30yz said:My table saw is, I think, the bottom of Charnwood' s range , mine is bang on.
Even with the original blade is was " not bad"
I do know how to set things up and due to experience (maybe) know why and how when things are wrong.
You mention cameras: mine have all the wiz bangs on them but I rarely use them as I cut my photographic teeth on
SLR 40 years ago and the relationship between iso, speed and f stops are just second nature. All skills are the same.
I think he's done that and they are accurate. Doesn't need them anyway they are just a distraction (it's the diagonals!!).And how to very simply check the accuracy of a square.......
