The only Tslot fixings I've seen for sale are for use with a T slot metal track which you can get from Axminter on this page.
If you do want bolts for use with slots created by a keyhole cutter you might be best making your own using a square nut which fits in the bottom part of the slot, a washer or two, some threaded rod and a wing nut.
