Suitable festool hose for ts55 AND domino 500
MrYorke
11 Jan 2012
Cardiff
So I've got my domino 500. I've also had a ts55 for some time. I'd very much like to get a festool extraction HOSE. Is there 1 that I can use on both machines.
I'd very much like to get a festool extraction unit but funds won't permit......so for now I'll continue to use my Henry
Hi ian. Just asked on an answer you gave as to which 1 it is and where you got it from. How do you find the flexibility of the hose? Have wondered how more flexible the festool hose is
The green 27mm hose is a lot more flexible than a Henry hose
Sent from my HTC One using Tapatalk
Replied on other thread
I find my henry's hose to as flexible as I want i couldnt imagine wanting any more flexibility though my henrys older the new ones may be more rigid
Yep the 27mm hose will fit the Featool tools you have.
If you are want to get a hose before you purchase the festal vac, then can I suggest the ordinary one, it's a lot cheaper than the anti static one. When you get the vac the anti static hose with come with it.
Of course they are other hose options out their that are cheaper, but if you intend going down the Festool route, then why noytstart.
