RichardG
If at first you don’t succeed have a cup of tea.
My workshop is a converted double garage. I took out the two up and over doors bricked up a plinth and then filled above with timber frame and insulation. On one side I put inward opening pvcu French doors and I’m getting water leaking in and I can’t work out how it’s getting though. I’ve tried a hose and it does leak but it takes a good 30 minutes or more before any water appears. However, it’s hard to work out where it’s failing. The pool of water appears on the floor in the corner.
I resigned myself that I’ll probably have to take the door out in the summer and redo the installation but wondered if anyone had any suggestions as to how it could be leaking and whether I can stop it. Some pictures which will give you some idea what I’m talking about.
Thanks in advance
Richard
Ps. The red line on the drawing is membrane than is under all the batons.
Thanks in advance
Richard
